| Author |
Topic  |
mrapp
492 Posts |
Posted - 05/22/2008 : 06:29:08
is this it???? how hard is it to change??? where can i get a new one??? how much should it cost??? any tricks of the trade, i should know???? I think I welded somthing together inside, as i cranked with a jump from my truck.... Now it will not stop cranking!!!!
Thanks in advance.
Galloway "AC" NJ 84 25'4" completed |
Justin
2491 Posts |
Posted - 05/22/2008 : 07:37:10
Yes that's it. Very easy to replace--just unbolt and rebolt all wires exactly as they are now.
You can get a new one at your local outboard parts shop...depending on make/model it should be between $30-50.
Disconnect your battery cables from the batteries while replacing. |
ROGUE I 1978 235 CC Newburyport, MA Formerly Rockland, ME |
mrapp
492 Posts |
Posted - 05/22/2008 : 08:17:48
| Thanks |
warthog5
Head Shark
12299 Posts |
Posted - 05/22/2008 : 08:18:42
| As Justin has said and yes you did weld the plunger. That is usually caused by cranking with a low battery. A low battery will cause the amperage draw to jump WAY up. |
Pensacola,FL
mrapp
492 Posts |
Posted - 05/22/2008 : 10:18:11
New one in carb and choke cleaner done.... she purrrrrrrrrrrrrsssssssss
Thanks Guys |
Justin
2491 Posts |
Posted - 05/22/2008 : 10:55:18
| That was quick! |
warthog5
Head Shark
12299 Posts |
Posted - 05/22/2008 : 20:47:21
It's just a 10min bolt on. :)
Pensacola,FL
Justin
2491 Posts |
Posted - 05/22/2008 : 20:58:30
I know but he went from not knowing where to get it to having it installed like 15 minutes later  |
Topic  |
