 Mako Discussion
 interlux VC underwater epoxy
brando
Crash Landing
Posted - 10/16/2012 :  10:16:03  Show Profile  Visit brando's Homepage  Reply with Quote
After having my bottom paint soda blasted off, I now have rough/pourous bottom. It sais it has a hard semi gloss white finish. Can anyone offer any insight on this or other recomendations? I'm afraid color won't match the hull.
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
http://www.classicmako.com/forum/topic.asp?TOPIC_ID=35081
Triplecrownnc
TC
Posted - 10/16/2012 :  10:22:43  Show Profile  Reply with Quote
Good stuff
Project Thread: http://www.classicmako.com/forum/topic.asp?TOPIC_ID=21067
Good Luck Chuck
Posted - 10/16/2012 :  10:37:24  Show Profile  Reply with Quote
It is hard as a rock. You will still have to fair the bottom to smooth out and wet sanding and polishing will yield a high gloss. I have seen mixed info about tinting, but it is a pure white that will not match the color of a Mako hull.
I have it and am very pleased.
'82 224 - Mobile, AL
brando
Crash Landing
Posted - 10/16/2012 :  10:58:10  Show Profile  Visit brando's Homepage  Reply with Quote
So therefore I need to paint the hull?
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
Good Luck Chuck
Posted - 10/16/2012 :  11:03:27  Show Profile  Reply with Quote
No, you can have two different shades of white. You are not likely going to match hull anyway, so do bottom and see how it looks. If you do not like different shades of white, try and break up with a boot stripe, and if still not happy put paint on the list for future project.
back-n-black
Posted - 10/16/2012 :  14:10:28  Show Profile  Reply with Quote
Interlux frowns on tinting this stuff. I used it and love the results. You have a window whereby it is easIER to sand and buff out. If you wait too long (after a week or so), it will be much harder to buff out.
It gives the bottom a fresh clean look.
Jim
Back-n-Black
1983 Mako 224
Davidson, NC
http://www.classicmako.com/forum/topic.asp?TOPIC_ID=37894
brando
Crash Landing
Posted - 10/16/2012 :  15:30:36  Show Profile  Visit brando's Homepage  Reply with Quote
I just talk to a guy who gave me a quote on doing this and he said you do not have to sand or buff it out after you apply it . he said he wet sand the bottom that applies to coats and that's it . he quoted me 1100 dollars to do the job . I don't have boat stands and building to put the boat in to do it .
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
Triplecrownnc
TC
Posted - 10/16/2012 :  15:42:30  Show Profile  Reply with Quote
Seems like skinny money to me,
Good Luck Chuck
Posted - 10/16/2012 :  15:47:15  Show Profile  Reply with Quote
It does spray on as a finished product, my mentioning wet sanding was to get glossy finish. It will dry with a semi-gloss finish and look fine. My was done outside on homemade boat stands , therefore I can't really comment on cost. Will you be prepping, does that price include materials, will he spray primer, sand primer smooth before applying VC, etc...?
Raybo Marine NY
Rob
Posted - 10/16/2012 :  15:52:56  Show Profile  Visit Raybo Marine NY's Homepage  Reply with Quote
when you tint it perhaps it is not a stable solution, applying it could result in unevenness or blotchy appearance when you sand it- that is just a guess of mine I have never used it but I cant see why interlux would not like people tinting it?
it will look PURE white and very off from the original mako hullsides.
Lindenhurst, New York
Please email me if you are seeking advice so that I can answer when I have the free time to devote to your question. Thank you.
www.raybomarine.com
brando
Crash Landing
Posted - 10/16/2012 :  18:12:52  Show Profile  Visit brando's Homepage  Reply with Quote
For the same price he will do gel coat if I want and match color
Cost includes delivery and pick up of boat, -To wetsand n buff all above chime edges both sides n
across transome where once was soda blasted off n then apply 2 coats
of Interlux vc off- shore without antifoul on the bottom underneath
only - est time n materials is $ 1,102.00 - breakdown goes as 5hrs to
wetsand n buff the soda blasted areas discussed in here n we get $12
pr ft plus materials pr way to do the bottom in the vc sealer from
interlux
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
Edited by - brando on 10/16/2012 18:14:14
Raybo Marine NY
Rob
Posted - 10/16/2012 :  18:38:00  Show Profile  Visit Raybo Marine NY's Homepage  Reply with Quote
Red flag if someone says they can spray gelcoat under there and sand and polish it for that price
www.raybomarine.com
Triplecrownnc
TC
Posted - 10/16/2012 :  18:52:28  Show Profile  Reply with Quote
that is what I was thinking
brando
Crash Landing
Posted - 10/16/2012 :  19:06:05  Show Profile  Visit brando's Homepage  Reply with Quote
He said gel coat cost about the same as the interlux. I have no clue but thought that didn't sound right.
My main goal is to correct the rough/porous bottom from when I had the bottom paint soda blasted. I'm all ears to either an economical fix for the time being or let it go and wait to do it right.
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
1973Mako23
Posted - 10/17/2012 :  07:46:13  Show Profile  Reply with Quote
That sounds fishy.I am no pro like Raybo but I got tons of time in gelcoating the entire outside of a 23.Probably had about 600 or so just in materials just counting gelcoat and hardner and another 200 for awlgrip supplies that was sprayed above the waterline.Got cheap prices on gel which was 10 gallons from advanced plastics
brando
Crash Landing
Posted - 10/17/2012 :  09:20:36  Show Profile  Visit brando's Homepage  Reply with Quote
I just got off the phone with another local guy who looked at boat. He said he would remove all hardware on transom, fill in any sings dents etc with epoxy&cabosil, apply 1-2 coats barrier then two coats of interlux $1200. Didnt mention anything about wet Sanding. Stated $400-$600 materials and rest is labor. I got this second opinion to prove myself wrong on the first guy and here they are on the same page.
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
Raybo Marine NY
Rob
Posted - 10/17/2012 :  09:46:50  Show Profile  Visit Raybo Marine NY's Homepage  Reply with Quote
roller or spray?
my comments before were in regards to the first guy saying he would spray and sand/polish gelcoat for the same price.
www.raybomarine.com
brando
Crash Landing
Posted - 10/17/2012 :  09:52:56  Show Profile  Visit brando's Homepage  Reply with Quote
roller or spray?
the second guy said he would prefer to spray
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
brando
Crash Landing
Posted - 02/18/2013 :  15:14:43  Show Profile  Visit brando's Homepage  Reply with Quote
When you say primer do you mean the interlux barrier coat 2000E ?
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
MakoShako
Posted - 02/19/2013 :  08:54:29  Show Profile  Reply with Quote
I roll and tipped mine w no primer ... It set up fast so dont roll too much on before tipping. I used Imtelux Perfection on the top and had a bootstripe put on to separate. FLY on top and white bottom ... Looks real good
72' Mako 22'
NoNeck, VA
Good Luck Chuck
Posted - 02/19/2013 :  09:03:47  Show Profile  Reply with Quote
Just saw this...I used Interlux Epoxy Primekote. I used because that is what my painter recommended .
keyman
Posted - 02/19/2013 :  11:06:50  Show Profile  Reply with Quote
I was told by Interlux that they have discontinued the manufacture of Interlux VC products because of carcinogen. I used Interlux 2000E for coating of gas tank. I believe that it can be used for sealing of hull too.
Keyman
Paoli, PA
brando
Crash Landing
Posted - 02/19/2013 :  13:51:01  Show Profile  Visit brando's Homepage  Reply with Quote
I better buy it soon. Honestly I am really dragging my feet on this project. I have to do it but half afraid of crawling under the thing. Regardless of how many how to's and what not to do I'm just not sure its worth the risk and aggivation. However I would be happy to save maybe $500-$600
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
Bdemir
Posted - 02/22/2013 :  05:20:45  Show Profile  Reply with Quote
I am in the process of this myself. I spoke with the interlux rep last week at the Miami boat show and he told me not to bother with primer and that VC is thicker and harder than 2000e. I didn't soda blast mine I just sanded but I don't see why u can't just paint right over it if its so thick like the rep told me. If I were you I would talk to interlux and try a section on the boat by roll and tip and see how it looks.
Bruno D
1989 211
200 yami 4stk
Miami,FL
[URL=http://s1303.photobucket.com/user/bdemir79/media/5746381f-5185-4083-b521-5be28638b96b_zps7857531c.jpg.html][/URL]
brando
Crash Landing
Posted - 02/27/2013 :  21:46:35  Show Profile  Visit brando's Homepage  Reply with Quote
Thanks for the heads up. I will look into that
1984 Mako 238 WA
2015 Suzuki 250 APX
Central PA/OCMD
This page was generated in 0.89 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
